Бушони (предпазители) и релета при Mondeo Mk3
Започната от Pyrhel, 07 Ноември 2011 22:40:44
В момента се сещам за 2 думи от българския език, които много обичам - "бушони" и "жици" :D
Информацията е за преди фейслифта (до 2004та година), след това може да има разлики, ще ги сравня в последствие и ще пиша.
БУШОНИ И РЕЛЕТА В ДВИГАТЕЛНИЯ ОТСЕК
  • F1 - 30A - ABS
  • F2 - 50A - Ignition Relay
  • F3 - 60A - Diesel Engine Heater
  • F4 - 30A - Heated Rear Window
  • F5 - 20A - Heated Seats (Facelift only)
  • F6 - 40A - Heater Blower
  • F7 - 50A - Main Power
  • F8 - 60A - Engine Cooling, Pre-glow relay
  • F9 - 20A - PCM Relay
  • F10 - 40A - Engine Cooling
  • F11 - 30A - Heated Windscreen
  • F13 - 30A - Heated Windscreen
  • F15 - 3A - Heated Windscreen
  • F16 - 20A - LH Xenon Headlight - 7.5A - LH Halogen Headlight
  • F17 - 10A - Automatic Transmission
  • F18 - 20A - RH Xenon Headlight - 7.5A - RH Halogen Headlight
  • F20 - 20A - ABS
  • F21 - 15A - Light Switch
  • F22 - 20A - Headlight Cleaning Relay
  • F23 - 7.5A - Battery Backup Sounder ( petrol ) - 15A - Injection Relays, Booster Heater (diesel)
  • F24 - 20A - Central Timer Unit - (may have some bearing on Direction Indicators & Hazard Light Function)
  • F25 - 15A - Central Timer Unit - (may have some bearing on Direction Indicators & Hazard Light Function)
  • F26 - 20A - Horn Relay
  • F27 - 15A - Fuel Pump Relay, Windscreen Heater
  • F28 - 20A - Ignition Switch
  • F29 - 30A - Starter Relay
  • F30 - 7.5A - Alternator
  • F31 - 7.5A - Air Conditioning
  • F32 - 3A - Automatic Transmission, Engine Control Module
  • F33 - 7.5A - PCM Module Relay
  • F37 - 15A - Oxygen Sensor
  • F40 - 7.5A - Engine
  • F42 - 10A - Engine
БУШОНИ И РЕЛЕТА В КУПЕТО
  • F60 - 25A - Electric Windows
  • F61 - 25A - Electric Windows
  • F62 - 15A - Light Switch
  • F63 - 7.5A - Direction Indicators - (may be related to the headlight switch & not indicators)
  • F64 - 7.5A - Direction Indicators - (may be related to the headlight switch & not indicators)
  • F65 - 7.5A - Air Conditioning
  • F66 - 30A - Drivers Power Seat
  • F67 - 7.5A - Alarm
  • F68 - 15A - Cigarette Lighter
  • F69 - 7.5A - Radio, Instrument Cluster
  • F70 - 15A - RH Rear Power Point (Estate Models)
  • F71 - 10A - Rear Seat Entertainment (Video Screens)
  • F72 - 20A - Radio
  • F73 - 20A - Sunroof
  • F74 - 20A - Trailer
  • F75 - 7.5A - Electric Mirrors
  • F76 - 7.5A - Air Conditioning
  • F77 - 7.5A - ABS, Traction Control
  • F78 - 7.5A - Instrument Cluster, Airbag
  • F80 - 7.5A - Automatic Transmission, Reverse Lights
  • F81 - 7.5A - Temperature Sensor, Automatic Transmission, Seat Sensor
  • F82 - 7.5A - Air Conditioning, Windscreen Washer Heater, Booster Heater, Cruise Control
  • F83 - 15A - Heated Seats
  • F84 - 20A - Light Switch
  • F85 - 7.5A - LH Headlight
  • F86 - 7.5A - RH Headlight
  • F88 - 15A - Low Beam Relay, Light Switch
  • F89 - 7.5A - Airbag
  • F90 - 15A - Rear Wiper Motor
  • F91 - 7.5A - Electric Windows, Dimming Mirror, Sunroof
  • F92 - 10A - Trailer
  • F93 - 10A - Headlights, Brake lights, Heater Blower Relay
  • F94 - 20A - Wash/Wipe
  • F95 - 7.5A - Low Beam Headlights
  • F97 - 7.5A - License Plate Lights, Glove Box Light, Central Timer Unit
  • F98 - 7.5A - Electric Mirrors, Heated Mirrors
  • F99 - Pre-Facelift 7.5A / Facelift 10A - Interior Lights
  • F100 - 7.5A - Multimedia Module (Inline fuse under the centre console - Pre facelift mondy)
  • F101 - 3A - CD Changer (Under the passenger front seat - Pre facelift mondy)
perder
А някой може ли да даде повечко инфо за бушоните F3 и F10 за какво служат точно?
Цитат на: perder в 10 Февруари 2013 15:23:55
Ф3 ти подгрева на мотора, ф4 е перката з  охлаждане.
Светослав
Здравейте :) Да попитам - къде са схемите за бушоните, че осветлението в купето не ми свети, май дадох на късо  ::)
Голяма част от снимките на шефа са изчезнали в небитието. :(
Ще ги оправя тия като седна пред компютъра. Ако видите и на други места липсващи снимки - драсвайте в темите да се виждат, за да ги оправя и там.
mirohristov
Цитат на: Pyrhel в 03 Ноември 2013 16:43:27
(wave)
Ето ги схемите.
1. Схема на предпазителите и релетата в двигателния отсек:
2. Схема на предпазителите и релетата в купето:
ZAPRINSKI
здравейте всичко е описано добре за бушоните обаче не разбрах за форд мондео бензинка къде е  бушона/реле за централно заключване копчето за отваряне на багажника което под касетофона и алармата ,благодаря предварително,весели празници.....
wolf_valley
#10
Здравейте искам да попитам от къде мога да си закупя цялата литература мондео МК3 хечбека от 2000 - 2003 година но да не е само ел. схемите но да са на Български благодаря предварително
chokolino771
Имам книжката на БГ колега,мога да ти я дам да си преснимаш каквото ти трябва или цялата и да ми я върнеш.
wolf_valley
Съгласен съм но в момента ме няма в къщи чак другата седмица към сряда - четвъртък ще се прибера ако си съгласен
chokolino771
Така или иначе си стой в жабката,като решиш драсни.
wolf_valley
Някой знае ли някой колко струва каталога и всички схеми и от къде може да се закупят за форд мондео мк3 само че да са преведени на Български ??? Благодаря предварително
Да питам...след фейса....бушон 84 в купето за какво е ? По схемата.....е за ключа за фаровете...а аз нямам такъв бушон, а си ми работи всичко ;)
housedreams
Бихте ли ми казали къде е този проклет бушон за отварянето на багажника.Търсих из форума,но не намерих отговор.Благодря предварително!
@housedreams
Отиди на https://www.ford.bg/users-manual и намери ръководството за твоя модел (ако не ме лъже паметта, моето съм го теглил от там), в него трябва да има по табла, кой бушон за къде е.
Също има и тази тема: https://fordbg.com/forum/index.php?topic=9884.0
В нея са събрани част от ръководствата/наръчниците на български език и препратки (links) към официалните източници на различни езици.
