Track Day cars
Започната от Pyrhel, 13 Ноември 2011 16:10:31
Новият рекордьор в драга е .... ралиджийка :D (notworthy)
Drag Sliven 2012g. - Audi S1 - 9.736 sec.
"UK ROAD LEGAL..Here we have a 1 off ''Field Motorsport'' 2.0 FOUR WHEEL DRIVE COSWORTH MK7 FIESTA WITH 550BHP, 0-60 SUB 3 SECONDS, THIS IS THE ULTIMATE TRACK CAR,
THIS HAS BEEN A LABOUR OF PASSION AND BUILT TO THE HIGHEST STANDARD AND SPEC WITH A ''MONEY NO OBJECT'' POLICY, HERE IS A BRIEF DESCRIPTION OF SPEC.
PLS CALL FOR FULL BUILD SPEC AND PICS,,YOU HAVE NEVER BEEN IN A CAR THIS QUICK....
CHASSIS
Mk7 fiesta 3dr shell with a modified 4+4 sierra cosworth floor pan The body kit is from old school engineering with a rear spoiler from mountune.
ENGINE
The engine is a field motorsport built 2.0 litre 200 block, 6 long-studded,
Garrett GT30 roller bearing turbo, matched ported and polished head, double valve springs ,BD16 inlet and outlet cams , RS500 inlet, 8 green injectors , p8 ecu with pectel piggy back board running coil conversion an anti lag , cosworth pistons , H section con rods , WRC oil injectors , flowed block , big wing sump with baffle plate , air tec intercooler , pace radiator , remote oil filter with mocal oil cooler, custom exhaust , external waste gate ,909 engine bay loom, 2 Bosch 044 fuel pumps running billet fuel rails. And much more
TRANSMISSION
Six paddle clutch with hydraulic set up, front diff 909 thick wall ATB , rear diff 909,gearbox is a Dennis osbarne dog box 5 speed standard ration 4+4 box, uprated drive shafts.
SUSPENSION
Gaz gold coilovers,adjustable top mounts , adjustable ARBs and track control arms, poly bushes front and back rear subframe has steel WRC body mounts.
BRAKES
Ap racing six-pots with 362mm discs at the front and 300mm reyland discs/bells/and spacers at the rear with braided brake lines through out the car with a hydraulic hand brake snd a bias pedal box.
WHEELS
Compomotive 18 alloy wheels with yokaharma tyres all round and spare. Another set of wheels for track only are a set of speed line 18 Dunlop slick tyers.
INTERIOR
Full muti-point cage weld in cage , retrimmed cobra seats , flocked dash, stack dash with track timing, oil temp fuel and oil pressure gages , full under the engine bay and in side fire extinguishers, cd player with blue tooth electric windows and power steering. Six point sparco seat belts shift light , cut out switch, gel battery, lexan rear quarters with custom fuel filler cap.
Private plate RS 09 COZ
Dyno proven at 556 @7500,533ft @4000rpm.
THIS IS A WORLD 1ST BUILD AND SOLD WITH THE ''RS 09 COZ'' PLATE"
И е годна за улиците ... да им имам законите на острова, тука за една клетка спират от движение :D
Иначе да се радваш ли, да плачеш ли ... 20+ години по-късно нищо не се е променило ... сиерови дъна, мотори и трансмисии.
Бием се в гърдите с 3 цилиндрови миксери дето бабата испанка ще ходи с тях до мола :-X
Цитат на: Danchev в 29 Август 2012 20:47:07
Новите мотори станаха прекалено изпилени  :-X. как да ги надуеш като самите от завода за на ръба на възможностите си....
Онази Фиесчика напредва ^-^
She's back ... but this time ... sideways (race)
Цитат на: Danchev в 21 Октомври 2012 03:44:55
Клипове? - това онова има ли  :P
Още едно дрифт коси е на път ... скоро и видео 8)
1.5 бара, 342 коня на гуми, 412 коня на мотора
Cosworth dyno tune
Подобни ФиЕвота стават все по-популярни последно време, като тази е една от най-силните, които са се появявали ... 720BHP 8)
