Нужна ми е малко помощ относно за разшифроване на грешка 0171
Започната от solo5, 04 Май 2017 21:24:05
solo5
Дали имам проблем с ламбда сондата?
Грешка: P0171
Type Powertrain: Fuel and Air Metering - ISO/SAE Controlled
Description: Fuel System Too Lean Conditions
Cause: Engine running at Cruise speed for 3-4 minutes,
then the PCM detected that the Adaptive Fuel Control System
was at its rich correction limit (due to a lean A/F ratio)
MID:$02 TID:$91
- O2 Bank 1 Sensor 2
Max: 7,99527V   Min: 0,0488V
Test result value: 0V
FAIL
