Спецификации на маслата за Форд
Започната от moni74, 02 Декември 2014 19:33:37
Motor Oils
Ford M2C913-A
Engine oil, Initial and service fill, SAE 5W-30. This specification meets the ILSAC GF-2 and ACEA A1-98 and B1-98 and additional Ford requirements.
Ford M2C913-B
The Ford M2C913-B specification is released in Europe for initial fill engine oils used for lubrication of spark ignition engines using gasoline and for compression ignition engines using diesel fuels. The specification is also used to define engine oils for servicing Ford engines where applicable. The oil shall meet all the requirements of the ILSAC GF-2 and GF-3 specification, the ACEA A1-98 and B1-98 specification and additional Ford requirements.
Ford M2C913-C
Fully backwards compatible and is strongly recommended for all applications that currently require the specification Ford M2C913-B. The new engine oil provides various benefits to the customer such as improved fuel economy benefits and high robustness to biodiesel fuels.
Ford M2C913-D
Introduced in 2012, oils meeting this specification are recommended for all Ford diesel engines except Ford Ka TDCi models manufactured before 2009 and Ford Galaxy 1.9 TDi models manufactured between 2000 and 2006. A product meeting this specification is especially recommended for diesel engines where M2C913-B or M2C913-C oils were initially required. An oil meeting this specification must be used in Ford Transit vehicles manufactured from 2012 onward with Duratorq 2.2 engine. Oils meeting this specification can be used with extended oil change intervals and are also suitable to be used in engines running on biodiesel or high sulfur diesel.
Ford M2C917-A
Viscosity SAE 5W40 engine oil for pump injector diesel engines.
Ford M2C934-A
Extended drain engine oil for vehicles equipped with diesel particulate filter (DPF).
Manual Transmission Fluids
Ford 8U7J-19G518-BA
Special gear oil for Ford Kuga's transferbox.
Ford 8U7J-8708687-AA
Special gear oil for Haldex clutches.
Ford M2C104-A
SAE 90 mechanical gear oil with EP additive and friction modifier.
Ford M2C175-A
API GL-4 grade, SAE 80W90 gear oil for Ford Type N transmissions made before 1990.
Ford M2C186-A
Friction modified transmission oil for Ford MT75 transmissions.
Ford M2C192-A
SAE 75W140 grade hypoid gear oil for regular and limited slip rear differentials.
Ford M2C192-A + M2C118-A
Synthetic hypoid gear oil with friction modifier.
Ford M2C197-A
Hypoid differential oil with EP properties.
Ford M2C197-A + M2C118-A
Special formula Trac-Lok for rear axles.
Ford M2C200-B
Synthetic, SAE 75W90 grade, API GL-4 or GL-5 level hypoid gear oil with extreme pressure (EP) properties.
Ford M2C200-C
Polyalphaolefine (PAO) based, synthetic gear oils.
Ford M2C200-D
Polyalphaolefine (PAO) based, synthetic gear oil with viscosity modifier and extreme pressure (EP) additive.
Ford M2C201-A
Thermally stable hypoid gear oil for front differentials. Meets MIL-L-2105D and API GL-5
Ford M2C918-A
SAE 75W90 grade synthetic gear oil for rear differentials.
Ford M2C94-A
SAE 80W90 or 80W grade multifunction hypoid gear oil. Meets API GL-5 and MIL-L-2105C.
Ford N052145 VX00
VW G 052 145 equivalent Ford specification. Fully synthetic, meets API GL-4 and SAE 75W90.
Automatic Transmission Fluids
Ford Mercon
Automatic transmission fluid specification for use in Ford automatic transmissions.
Ford Mercon V
Ford Mercon V specification. An automatic transmission fluid with improved protection against rust, corrosion, deposits and wear. It improves low-temperature shifting and guards against transmission shudder. Mercon V is fully backwards compatible with Mercon.
