Mondeo Mk4 - Схема на предпазители (бушони) и релета
Започната от Bobi, 03 Септември 2012 07:38:23
Engine compartment fuse box
Fuse and relay layout
Engine compartment fuse box, also known as Engine Junction Box (EJB):
Fuse types
Conventional mini blade fuses (F1-F2, F6-F14, F30-F33, F36-F45);
square 895-series JCASE fuses (F15, F22-F29, F34-F35),
bolt-on 498-series MIDI fuses (F3-F5, F16-F21).
Fuse information
F1 – 10A – Transmission control module;
F2 – 5A – [Diesel engines] Glow plug monitoring, [1.6 Duratec-16V Ti-VCT] Degas valve;
F3 – 80A – [2.3 Duratec-HE for the Middle East countries] Engine cooling fan - twin, [2.0 Duratorq-TDCi] electro-hydraulic power-assisted steering (EHPAS);
F4 – 60A – Glow plugs;
F5 – 60A – Engine cooling fan - single;
F6 – 10A – HEGO/Lambda sensors 1 (engine management), variable valve timing (engine management);
F7 – 5A – Relay coils;
F8 – 10A – Powertrain control module ECR;
F9 – – Not used;
F10 – 10A – Engine control module;
F11 – 10A – Valves, MAF control (engine management);
F12 – 10A – [Diesel engines] Water in fuel sensor, coils, MAF (engine management);
F13 – 15A – Air conditioning relay;
F14 – 15A – Diesel filter heater;
F15 – 40A – Starter relay;
F16 – 80A – Diesel auxiliary heater (PTC);
F17 – 60A – Central fuse box supply A;
F18 – 60A – Central fuse box supply B;
F19 – 60A – Rear fuse box supply C;
F20 – 60A – Rear fuse box supply D;
F21 – – Not used;
F22 – 30A – Windscreen wiper module;
F23 – 25A or 30A – Heated rear window (replace with the same A rating as the one removed);
F24 – 30A – Headlamp washer;
F25 – 30A – ABS valves;
F26 – 40A – ABS pump;
F27 – 30A – Fuel fired heater;
F28 – 40A – Heater blower;
F29 – – Not used;
F30 – – Not used;
F31 – 15A – Horn;
F32 – – Not used;
F33 – 5A – Light switch module, engine compartment fuse box coils;
F34 – 40A – Heated windscreen, LH side;
F35 – 40A – Heated windscreen, RH side;
F36 – 5A – Anti-lock Braking System (ABS);
F37 – 10A – Heated front washer jets;
F38 – 5A – Adaptive cruise control (ACC);
F39 – 15A – Adaptive front lighting system (AFS);
F40 – – Not used;
F41 – 20A – Instrument panel (15 feed);
F42 – 10A – Engine control module, transmission control module, Electro-hydraulic power-assisted steering (EHPAS) (15 feed);
F43 – 5A – Headlamp levelling, adaptive front lighting system (AFS) (15 feed);
F44 – 20A – [2.5 Duratec-ST] Vacuum pump (15 feed);
F45 – 15A – Rear window wiper (15 feed).
Relay information
R1 – Starter relay;
R2 – PCM relay
R3 – Air conditioning clutch relay
R4 – [Diesel engines] Glow plug relay, [1.6 Duratec-16V Ti-VCT] Degas valve;
R5 – Cooling fan relay;
R6 – Heated windscreen relay;
R7 – 15 relay;
R8 – Windscreen wiper intermittent wipe relay;
R9 – Horn relay;
R10 – Headlamp washer pump relay;
R11 – Windscreen wiper on/off relay;
R12 – Auto Trans Startlock relay.
Central fuse box – fuse information
F1 – 5A – Rain sensor module;
F2 – 10A – Supplemental restraint system (SRS) supply;
F3 – 5A – Yaw rate sensor (for ESP);
F4 – 7.5A – Electronic 15 feed, accelerator pedal supply, electronic fuse;
F5 – 15A – Rear window wiper relay;
F6 – 15A – Audio system (including voice control module);
F7 – 7.5A – Steering wheel module;
F8 – 5A – Instrument cluster;
F9 – 15A – Main beam supply;
F10 – 20A – Power sunroof supply;
F11 – 7.5A – Reversing lamps relay (30 feed);
F12 – – Not used;
F13 – 15A – Front fog lamp supply;
F14 – 15A – Windscreen washers supply;
F15 – 10A – Adaptive cruise control (ACC);
F16 – – Not used;
F17 – 10A – Interior lamps;
F18 – 5A – Engine immobiliser;
F19 – 15A – Cigar lighter (including rear seat lighter socket, where fitted);
F20 – – Not used;
F21 – 5A – Remote frequency receiver, Interior motion sensor;
F22 – 20A – Fuel pump;
F22 – 7.5A – [2.2L Duratorq-TDCi] Fuel pump;
F23 – – Not used;
F24 – 5A – Ignition switch;
F25 – 10A – Fuel filler flap unlock;
F26 – 5A – Battery backup sounder (alarm system), OBD II (on-board diagnostic system);
F27 – 5A – Steering column unit, climate control module;
F28 – 5A – Brake lamp switch.
Rear fuse box
Fuse information
FA1 – 25A – Door module, LH front (window up/down, central locking, electric folding mirror, heated mirror);
FA2 – 25A – Door module, RH front (window up/down, central locking, electric folding mirror, heated mirror);
FA3 – 25A – Door module, LH rear (window up/down);
FA4 – 25A – Door module, LH rear (window up/down);
FA5 – 10A – Rear locking (without rear door modules);
FA6 – 15A – Auxiliary power socket;
FA7 – 5A – Relay coils;
FA8 – 20A – Steering column lock;
FA9 – – Not used;
FA10 – 30A – Power seat, driver;
FA11 – 20A – Accessories, trailer module;
FA12 – – Not used;
FB1 – 5A – Parking aid module;
FB2 – 15A – Suspension module;
FB3 – 15A – Seat heater, front – driver;
FB4 – 15A – Seat heater, front – passenger;
FB5 – 15A – Seat heater, LH rear;
FB6 – – Not used;
FB7 – 15A – Seat heater, RH rear;
FB8 – – Not used;
FB9 – 30A – Power seat, passenger;
FB10 – 10A – Anti-theft alarm horn;
FB11 – – Not used;
FB12 – – Not used;
FC1 – – Not used;
FC2 – – Not used;
FC3 – – Not used;
FC4 – – Not used;
FC5 – 7.5A – CD changer, rear seat entertainment system;
FC6 – – Not used;
FC7 – 5A – Power seat memory function module;
FC8 – 20A – Keyless entry;
FC9 – – Not used;
FC10 – – Not used;
FC11 – – Not used;
FC12 – – Not used.
Relay information
RA1 – Heated rear window relay;
RA2 – Rear window wiper relay;
RB1 – Rear 15E relay;
RB2 – Anti-theft alarm horn relay;
RC1 – – Not used;
RC2 – – Not used.
Central fuse box, also known as Auxiliary Junction Box (AJB) – fuse information:
F12 – – Not used;
F16 – – Not used;
F20 – – Not used;
F23 – – Not used;
