Моделите на Форд => Focus / C-Max => Темата е започната от: олег в 21 Юни 2014 20:24:34
Заглавие: Грешки при Фокус
Публикувано от: олег в 21 Юни 2014 20:24:34
При тестване на автомобила ми излязоха следните грешки на дисплея dtc#01 D 900 ,dtc#02 E510,dtc#03 9600 Ако някой знае какво означават моля нека ми помогне .Не мога да запаля колата
Заглавие: Re: DTC КОДОВЕ ЗА ФОРД
Публикувано от: Nebhotep в 21 Юни 2014 20:34:45
The instrument cluster fault code D900 means...." non specific can communications interruption "
This does NOT mean you have a fault on the car. It's merely reporting that the networking around the car had an unidentified interuption in power supply.....so.....had a flat battery or jump start recently ?, maybe battery been disconnected for some reason ?
If the answer is no to the above, then have your battery tested. If battery is ok, have a battery reset done and code should disappear. ( remove negative lead from battery and hold to +ve lead for 2 minutres).
Its really nothing to worry about...the 01 is the code count...i.e. If you had 3 faults it would read 03 D900, D184, D251 etc,
